Whiteline rear arb?
bristolsparks
178
Hi guys, maybe a stupid question but here we go
Is a 22mm whiteline rear arb really worth it?
All i can see is its bolted to the rear axle beam so does it actually do much?
i have a LC 180bhp 2003,
Cheers chaps
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
ha ha, yes it does much... rear arb is one of the best mods you can do for the cash... whiteline is a good way to go, make sure you get the adjustable though, as 22mm is quite thin but 3 levels of stiffness helps with this.
search on arbs then you will see how they are worth it
james walker
May 24, 2007
5,121
retford notts
then dnt get them to fit it, obviously havent a clue mate.... no real knowledge of the handling on a leon cupra either by the sounds of it.....
bristolsparks
178
i see there pretty easy to fit DIY? just a few bolts by the looks of things, might give it ago myself
james walker
May 24, 2007
5,121
retford notts
yup pretty easy job, bolt to rear axle with the supplied clamps, then bolt to suspension cups, put it strait on stiffes setting mate.
be sure to use plenty of grease on the bushings you get with the bar....
bristolsparks
178
oh might have to have a look into that then, u have to drill the upper strutts dont you? not sure about the lower one
Im sure there is a fitting guide somewhere on here
james walker
May 24, 2007
5,121
retford notts
yeah, drill 3 holes when measures up, bolt through from under the arch, bolt with nyloc nut on the top...
lower is a piece of, bolts into the two obvious holes into the subframe with the rivnuts youll need to get with the brace.
http://www.seatcupra.net/index.php?option=com_content&task=view&id=509&Itemid=6
guide for upper and lower with part numbers:funk:
D.K
LCR 225
Oct 24, 2007
6,408
se london
What would happen if you fit the rear ARB and leave the front one standerd on an LCR ???
Would this create too much oversteer ???
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
I have a rear Whiteline ARB on the stiffest setting with just an upper strut brace up front and the handling is ok, haven't experienced much over steer at all
