whos got what offset??
Jayt
201
having a bit of a dilema, i have a set of 19's, and could fit them with a set of 20mm hub adaptors problem is it will put the wheels out to an offset of 25mm. i'm just wondering does anyone on here know what the max i can get away with on my FR+ tdi would be? they reckon anywhere from 35 - 45mm is the acceptable amounts. but i know alot of people on here space them out to clear caliper and fill the arches so i just want to hear what you guys are running and if you have any problems.... thanks in advance.
kenny-cupra
Newbie
Sep 7, 2005
334
Renfrew
how wide are the wheels , as i have 8.5"x18" with a et 30 on a 225/40/18 tire fitted all round , no problems but the front wheels just sit pass the front arches and the back sit just on the arch and this will change over the next few weeks as i get round to fitting 10mm too the rear
Cheers Kenny
Jayt
201
the wheels are 8 inches wide and have a set of 215-35 r 19 tyres.
Jayt
201
now its all too confusing, but i might just buy the adapters and try them out, but its an expensive experiment at 100 quid a pair.
RobDon
Pro Detailer
ET25 will sit way too far outside the arches and most likely fail an MOT like that (it would look daft too!). ET30 is probably the lowest you can get away with on a Leon. I run ET35 with no spacers and they sit right at the edge of the front arches.
D20vt
Newbie
Sep 17, 2006
126
this is 8,5J 19" ET 25:
This is 8J 19" ET 30:
Front:
Rear:
Yours will be 5mm wider
Jayt
201
the back looks like it would be ok, but the front looks exceptionally tight o it does.. cheers for the photos.
