OOh someone organise us a group buy. Id have one for £80 my sx didnt come with a trip computer and id like to know my mpg.
was just about to say you will then be looking at import taxes.
i would sort a group buy if people are interested??
i can find out where the rs lot orderd theres from.
Here are some of its feature:
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
Maximum Speed
Average Speed
Maximum Coolant Temperature
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Distance to Empty
Time to Empty
Fuel to Empty
DIGITAL GAUGES
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Manifold Pressure (not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
SCAN TOOL
The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
Reads Trouble Codes
Reads conditions that set the Trouble Code
Clears Trouble Codes
Turns off the "Check Engine" light
Tells you when vehicle is "Ready" to pass OBDII testing
Make and store up to 10 rewritable special codes
to send to the vehicle computer
With this you dont have to plug in your laptop for faults. Do it then and there.
does this thing give any more info than i dont already get from the standard lcr trip computer?
I was wondering the same thing. I think the answer is yes, it definitely does, but how much of that is actually useful on a regular basis I'm not sure about.
Good gadget if the price is right, but not sure of it's benefit yet.
Looks like it could be useful for reading fault codes. Call me stupid but when it throws up a code, how do you know what it means? :blink:
