wind deflectors
matt l
391
mine went in alot easier than on my corsa :lol:. just bend them a little but but obviously not too much as they will snap, then put the window up and downa few times.
mcculloch
SEAT LEON ST FR 2.0TDI
Mar 25, 2008
134
8
Kilmarnock Scotland
Yeah as said just kinnda bow them a we ebit and they go in fine, just member n check that they are right bhind the seal at mirror end or the window stops half way up n goes back down, been there done that lol
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
If memory serves me correct, this can be reset. I think you need to locate and remove the fuse for the electric windows. The ECU should recalculate the load on the window motor to the new tension the window seals are now exerting on the glass. I may be wrong but, worth a try.
Rhine9
Hi mate, did you get them of a german bloke off ebay?
I had mine off there and with a bit of messing around there fine. i had the same problem with the window retracting all the time.
Found out this was due to the plastic frame nearest the wing mirror catching the window slightly, so with a bit of adjustment you can make it miss by pulling it away from the window.
Mines been fine ever since.
Good Luck
smart_search
www seatcupra.net/forums/showthread.php?t=188591&highlight=wind+deflectors
www seatcupra.net/forums/showthread.php?t=170936&highlight=wind+deflectors
www seatcupra.net/forums/showthread.php?t=137249&highlight=wind+deflectors
www seatcupra.net/forums/showthread.php?t=131285&highlight=wind+deflectors
