Window Condensation
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
OK the missus has a 1.2S '04 Beezer and it has manual aircon rather than climate control, recently she has complained that the heater takes 3-4mins to clear the windscreen.
She says the aircon snowflake is on (so it's not the old aircon slipping off when it's really cold).
Now I admit the car would demist quicker if she was moving but she says there is too much condensation.
Is it worth me renting a commercial dehumidifier and sucking the moisture out of the car????? is this a common problem on the Beezers :confused: :shrug:
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
i know on the diesels the heater doesnt work till the engine is getting warm , it recirculates the coolant around the engine instead of the heater matrix , or something like that , pain in the A55
Johnsey
SNAFU
Dec 23, 2003
912
Here & There
www.google.com
It does it on mine in the cold months Steve, although mine's the derv with Climate Control. As stated it's a PITA
Johnsey
SNAFU
Dec 23, 2003
912
Here & There
www.google.com
Ruddmeister said:
Thanks guys......me thinks the wifey will be less than delighted that the answer is keeping 5 yards of kitchen roll in the car ;)
I always found, the more contact you have with the glass the worse the issues get. I can't stand people wiping their sleeves on the windows or clearing it with their hands. I give them a good clean with ClearVue (I think that's what it's called by TurtleWax) and that seems to work on the rest of the glass pretty well.
mrcoyote
See no evil...
Jul 26, 2004
2,624
Didn't rain-x make some kind of anti fog stuff? I think it came in a pink bottle or something.. :gay:
dalepearson
Gadget Freak
Mar 25, 2004
1,376
West Midlands
RainX do have an internal anti fog solution and it sucks. Buy something like Autoglym glass cleaner, the cream not the spray, and give a good clean with that. Should help.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Are you sure the snowflake only comes on if the compressor is working - or is it just controlled by the aircon control ?
I've noticed the external temp sensor on my car under-reads by about 3ºc; if the aircon takes it's readings from the same sensor, it'll disable itself when it doesn't need to. IE if the aircon should shut off at 4ºc, on mine it wouldn't work below 7ºc.
dmjw01
Upstanding Member
Jul 28, 2005
442
Woking, UK
www.dmjwilliams.co.uk
I keep a plastic watering can in the back of the car. Fill it up with water from the cold tap and poor it over all the glassware. This does two things: it melts the frost on the outside and removes the mist from the inside. Don't be tempted to use warm water though, in case you crack your windscreen!
depresion
484
The best bet for anti fog stuff is to speek to a motorbike factors as they stock the sprays for inside helmits.
