Thanks guys. I'll keep that in mind.
I'm only hoping to keep it for a couple more months then I'll return to a Cupra or 350z.
I'll chalk it up to one of those things and post any further if it does reoccur
Sent from my One using Tapatalk
Just seen this thread is still going.
No update from me, only happened the once in 100,000 miles and 7 years.
Never bothered taking it to a main dealer for a diagnostic check, just continued to have it serviced by my local indy.
HTH
Hi ,
Not sure whether it will help but I had a mk3 golf gti which had a similar problem !sometimes the fronts sometimes the back and fronts !! It was strange to watch and happened for a couple of months before I solved it .
I the end I traced it back to bad connectors on the wiring loom between the front drivers door and the a pillar
Rather than the loom passing straight through it had a circular multiplug on the pillar . It was these connectors with the corrosion causing this weird fault !
Not sure if the Leon's use the same principal but it's worth checkin
