Mar 17, 2007
635
montrose scotland
well i have got my windows working now since not working since i bought my cupra 3 1/2 weeks ago what a pain in the a*se its been.it was in at the local seat garage they swapped both the motors and got them to work but i cant operate the passeger side from the drivers switch.any help.they said there might be faulty wiring some where please help
yea but they said it may take a good few hours to trace a break it a wire etc just thought some folk on here would be able to help if they have had the same problem or if there was anything that i could do thats all
Yeh my guess would be its just the switch! They probably swopped the duff switch from the drivers side driver window on to the drivers side pasenger window.
If that makes sense! I did it when my drivers side switch packed up takes 5 seconds to do until u buy a new switch
they said they had checked the switch and said it would be a faulty control unit or a break in the wire some where do you hink there trying to scam more cash out of me
try the switch yourself take it out and swap it for the working one. It will only take a few minutes but at least you will put you mind at ease that it isnt that!
If it doesnt work try cleaning around the pins that connect together, take the door card off and check around the motor do the same. If all of this fails while the door car is off you will be able to trace back the wires to see if there is any damage.
yea get a clicking noise from the passenger side button.and get a clicking noise for the drives side to operate the d/s.but when i go to use the d/s for the p/s there is no noise at all.i tried swaping the switches and it works so what can i do next help
