Wireless Android Auto - Works!
scuj1
75
13
Edinburgh, Scotland
After collecting my FR Sport over a month ago I noticed that Wireless Android Auto did exist within the infotainment system (brochure says wired only) but the way the WiFi is set up you'd need to use (and pay for) the eSim Data Plan. If you didn't, Android Wireless would still work but only with the data (music, maps etc) that was cached on your phone.
So after a bit of tinkering and head scratching I finally got a workaround and it now works flawlessly!
First thing to do is turn off the Integrated Data Connection (eSim)
You'll see up on the top right, this creates a notification about this...
This will come up every time you start the car if you select the notification and at first I thought that this might affect the app for checking the vehicle information, turning on hazards, horn etc but thankfully it doesn't. This continues to work normally. The only potential issue I can foresee is that OTA updates may not work? Until there's a new SW version available I won't know but if it does affect it, it would just be a case of activating the eSim periodically to get any new updates or it may even download it via your android device. The globe however still shows white to confirm it has a connection. Whether this is through the infotainment system itself or via you data connection on your phone, I'm not sure but it still continues to connect to SEAT's servers as normal.
Next, make sure the Infotainment System is still active as a Hotspot...
Your device should now see the vehicle WiFi as available and it shouldn't attempt to ask you to sign in to the network (as eSim is off) to sign up for the data plan, it should just connect automatically.
Now on your device under you WiFi and Network settings you should have menu called Dual-Channel Network Acceleration or similar (dependent on your device). Select this and you should have something similar to this option...
Basically you want to have the Intellligent Network Connection activated to stop your device trying to purely get data via WiFi. As there will be none apart from what is going between your device and the infotainment system. This will allow your device to still send and receive data on your mobile network which in turn will mean you can stream music and use google maps as normal as if it was wired and that's it! You should be good to go!
I may have done more than needed to get this all working but I'm just glad to have something SEAT don't even advertise as being available, unless they really wanted to push the data plan on to us for it!
Now my next problem is, I now need a new phone with wireless charging 😂
Any questions, just let me know!
Reactions: Torque69 and Tell
dan555
241
95
What android phone do you have?
What software version is the infotainment?
It seems you Android auto looks different from mine being full width instead of a box in the middle of the screen
I wonder if it could be a later head unit, which allows wireless AA
Jimbobcook
6,150
2,533
I think Wireless AA is only available on Android 11 (also maybe specific phones)... I read that a while back on the Google troubleshooting page...
May of changed since then
Reactions: dan555
scuj1
75
13
Edinburgh, Scotland
Hi Dan,
I have a OnePlus Nord. It was on Android 10 when I first got the vehicle but is now on 11.
Current software version...
Android Auto has always been widescreen since I've had the vehicle even when using wired. You're not using MirrorLink by any chance?
It could well be an updated unit. My vehicle was built the first week of January.
RoadXY
66
19
I have this notification for the past three days but I stil have the eSIM enabled.
Reactions: Jimmymac
manracer
52
25
I tried this just now and it didnt work for me.
Huawei P30 Pro (running android 11)
manracer
52
25
You'd think it would be more or less the same in the Formentor too.
Yes you would - so many bugs in this system too.
Today i looked into customising the individual profile again and every item (DCC engine etc only had the option of "off road"), yet when I turned engine off and back on it was back to normal.
I also find it amateur you can get into the service menu just be holding over the circular button bottom left of the screen.
scuj1
75
13
Edinburgh, Scotland
Have you set up your profile? This also happened to me the first couple of days but seemed to sort itself out after.
manracer
52
25
yes profile set up, I did momentarily switch to guest so perhaps that was the reason.
Tell
Interesting. It was only suppose to be available on the Zn2 looking at the German Seat site when I was researching mib3 units. All the UK ones are Zn1 including the Cupra's so decided that it wasn't possible. Probably it's just turned on in a Zn2 and you have found a way of avoiding whatever was put in place or not enabled 😍.
dts0205
17
I tried to set mine up when I got it but gave up. A few weeks ago I got in the car and it connected wirelessly on its own.
I'm on Android 10
