You do get a code it's how I run mine you get a code because there is no vacume/ air flowing through the valve the only way to properly bypass it and have no code is to fit the 10w 330ohm resistor , rob don has done it I haven't yet but will
Same reverse N249 and see if dans rite :shrug: can't think of anything else
I assure you I don't . I get codes for my decat and that is all!
Yea same Danny I get a lamber code but no leak code beside this is causing limp ;)
Dude try revising the bypass before you go spending money on the map sensor just incase ;)
;) where did you get your spacer from for your 007?? I think I might try it out :)
quick question, if i buy a 225 steering wheel, without the center (air bag) would mine from my current steering wheel fit.
pic
For a moment there I forgot we were both called sam an wandered WTF you were on about :doh: lol
