did you use a clear lacquar?
Yep I did but the colour changed alot still. There must be the laquer in the paint.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Not had the time to scan through all the pages as yet so chances are this has been said before-
You know you have a MK2 Ibiza/Cordoba when you fix a fault and straight away another fault shows up.
Said many many times that a mk2 should 'always' have at least one thing wrong with it, because if it doesn't it is just about too!!
You know you have a Mk2 when:
- You can change the clutch cable in an hour
- Fitting a new clutch cable changes the clutch pedal feel completely
You know when you have a MK2 when its pissing out oil left, right and chelsea, the exaust is making some really random unhealthy sounds, and every attempt to fix it, it gives you the finger, but still you look at her and say 'i'd never own another car' lol
You know you have a mk2 GTi 16v when you start it up in the cold and the MPG guage tells you your doing 5.3![]()
5.3?? your lucky , i average 4.5 for first 2 miles.![]()
