im getting my grease tomorrow or Friday.
If i manage to add the grease to the MAF sensor, anyone will be able to do it![]()
I remember reading somewhere (can't find it now of course) that on switch off the ECU puts a high current through the MAF wires to heat them up and remove residues and moisture .... but I'm not 100% on this.
any petrol people tried yet as the maf works in the same way! ill try and get some at the weekend or ebay lol
As I posted back in message 33:...sod all difference !
Having said that, I've always thought the engine in the Passat has run really well with regards to smoothness, and even with 113k miles on the clock still starts on first turn.
Another couple of days might show if it's affected smoke output or MPG at all.
Given the number of people who've reported good improvements after this "mod", it obviously does work, just perhaps not on every car.
But at a cost of £3-4 it's got to be worth a try.
Well....I got home yesterday and my grease had arrived.
Desperate to give this a try, I went out in the cold, dark evening armed with the grease and a torch, and eagerly unplugged/replugged the MAF and MAP a few times, then made sure the contacts were plugged full of grease.
Had a quick drive around last night, and did the long drive in to work this morning, and....
