croakey
Hey!
maybe someone can give me advice on how i go about removing the gearknob from my 06 sport...
long story cut short..have a cracking plastic noise occasionally and a refusal to change gear (normally 2nd)..have taken it back to seat..and being the nice guys they are..they charged 37quid saying they couldnt establish a problem
so what i'm wanting to do is to take the knob and gaiter off... remove the knob from the gaiter...and drive with no gaiter on there leaving the gear selector mechanism exposed..so i can see for myself whats making the noise and problems
then i can go back..punch the service manager.. and get my 37quid back :)
cheers guys
lol ^^^ if its like the cupra the section of plastic nearer the dash slides off to the right and simply unclip by lift the rest of the gaitor upwards then remove the knob. have they checked the gear linkage that sounds like it could be a possibility m8
:lol:
if it's the same on all mk4's as it should be grab the plastic at the base of the gaiter in front of the stick and pull it up firmly then it should just slide up with the lower plastic bit attached too, then you'll find a brass clip, bend this so it slides off the gaiter support ring (flimsy plastic clip that hold the top of the gaiter flush with the bottom of the gear knob) unclip the clip, twist off knob, remove gaiter replace knob and brass clip. be carefull with the meatal clip as i broke mine when replacing the gear knob :cry:
i think thats how you do it, it's been a while since i done it, just be carefull NOT TO BRAKE THE CLIPS right pain in the :censored: if you do
cheers boy..i'm gunna have to have a bash 2moro..
proper ****s me off i bought a brand new car and even though its wrong..they wont fix it under warranty as in the 10 mins they looked at it they could suss it!
aint had chance yet..been flat out with uni work and proper work..plus its been pissing it down..
gunna have a look tomorrow, but i suspect the linkage is either faulty or theres something fallen into it
either way i'm going to find it, sort it, then punch the service manager :)
file a complaint about the lack of intrest in finding the problem with your vehicle then things might start rolling with the seat main stealers!
i am indeed...letter went off yesterday to SEAT UK...takes the piss charging to look at something that is clearly not right from day one.
not a happy bunny with amethyst cheltenham :)
if anyone out there has a name of a decent SEAT dealership i would like to know, as all i have heard and with personal experiance is that most are SH**E
all crap down where i live bad service! there is aseperate forrum on this site where you discuss seat dealerships good and bad should take a look!
