nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
here's my graph. tell me what you make of it.
spec is;
Green dynatwist
Samco TIP
K03s
Forge Actuator
Forge 007dv
Forge FMIC
Blueflame 2.75" downpipe
Blueflame 2.5" system
4 bar FPR
look how low the transmission loss is.? :blink:
anyone have any idea what the rule power bit means?
lol. :D i mean the low transmission losses! i wonder if anyone knows why it's so low?
i think its because they calculate it where your peak power is and because its quite low down the rev range the transmition loss isnt as high. if you peak power was at 6k your transmition low whould be high as you can see from the line in the graph
That graph looks impressive, and far better than mine!
Here is the graph of a remapped K03 for comparison against K03s:
Can see that spike you've talked about. The torque peaks, drops quickly then holds like a 'normal' k03s map. That'll be the acuator :D
Where abouts in the country are you Nick? Should meet up and compare mate :)
so if rule power is the corrected power, that means on paper i'm running 256bhp?
i had a go against my mates 235bhp Ibiza lst night and in 2nd and 3rd i hit boost alot harder and faster than him so i pull away, but it levels out again in 4th onwards. mine is definately very fast in the lower gears.
i'm in windsor mate, not too far from you i don't think. we should arrange something
on a k03s this all sounds a bit mumsy (big figures make customers happy). anything over 200 at the wheels is optomistic I believe.
