woojah
Hope you all can help me out on this one.
I was parking the car tonight and noticed that whenever I turned the steering wheel, the headlights would dim slightly. It doesn't dim by much, but it's defintely noticeable. I quickly figured that it must be the electric power steering 'stealing' power from the headlights.
My question is: is this normal? If not, it will be straight to the dealers for them to look at (I've only had the car for a couple of weeks).
It seems really strange for this to happen - a poor design fault maybe? :shrug:
PS I have an Ibiza DAB.
pretty normal usually just the drag from the power steering pump pulling a bit on the alternator in turn lowering the battery amps and dims the lights a tad - especially when parking or on tickover
try to replicate and then use a few more revs to see if it cures it is usually a key to checking what that is
pretty normal considering some small cars with small engines trying to run all the toys and standardish batteries
yup, quite normal for the voltage in the battery to drop when a sizable motor is driven
you will get the same thing with the electric windows, especially if you press up when they are already fully up
also the same if you put the heater fan of full or the rear heated screen, both of these devices draw a fair bit of current
and it's not just the ibiza, I have seen this on countless cars
Thanks for the reassuring replies. I've never noticed it in other cars before, but now that you've told me I'm sure I forever will!
Flapper - coincidentally I live in Cheltenham too. Small world huh?
happens with a sub as well, mine pulse to my music some times lol but anything electric will draw amps away from the lights!
Mine did it too, very noticeable when parking.
The upside of electric power steering is that it's only sapping power when you're actually steering, the engine isn't driving a hydraulic pump all the time like "traditional" PAS, all helps contribute to economy...
cool - whereabouts - theres a few others round here and closeish as well mind too
Just outside town, towards the station. Where abouts are you?
I went to test drive the Ibiza at Amethyst SEAT over here. They didn't seem keen to move on the list price and offered a pathetic part-ex price for my car, so I took my business elsewhere!
mine doesn't do it as much on the derv as it did on my petrol, don't know why? maybe a steadier idling RPM
diesel have up to 24v where as petrol cars have 12v
Up to 24v!! Really?? Could this possibly be the reason why the led sidelights people keep fitting stop working? cos they will have resistors in them matched to a 12v supply
if it doesnt state on the led packaging that it handles 12v-24v then this could definatly be your problem! specially when car isnt started and led's are turned on with all 24v going thro them!
only stated !some! diesels run on a higher voltage battery more trucks and stuff! at work we have to use two battery jump packs to get a some dead diesel batterys moving as takes more power to crank the engine over hense why there is a bigger alternator as the charge demand of a more powerful battery is much higher! i learnt this when i tryed to jump my petrol engine off my old mans diesel the amont of sparks from my12v battery when i connected the possitive! and no i didnt put them on the wrong way round but majority of cars have 12v batterys fitted. but you can get 24v car batterys
