is the garage a VW specialist like JKM?
If not - it might be worth talking to them.... it could (and more than likely) will be something like the N75 valve which controls the boost
I had a problem with a hairline crack in the hose connecting the N75 to the actuator - this led to erratic boost control.
The crack was diffficult to see - I had take the hose off to check it properly.
My car now has the same problem as you mate, you probrally remember me pulling 265hp at JKM in December, now I can only pull 240 ish, they said my car runs on the RR just like yours, also they said that your car had this problem about 3-4 months after you had Revo?, if this is right my car is the same.
