I'm gonna put some of this DPS4 in my 130TDCI Mondy.
I am finding it hard to find!
speeding.co.uk are the only place I have found!
I idealy want to go to a shop and buy it. Do you recon Motormania or Halfords might have it?
Millersoils.net don't even have it!
stockists can be searched for on the Millers website :)
i tried the site, found 2 in N.Ireland! none near me! but the other day if ound Millers oils in a motor store near me, but didnt really know about the adiitives to even look out for them, dont recall seeing them. Info on posts usefull so may have another look and if successfull in even finding the 'older' + stuff will give it a go.
Well, I've had a first. First time my long term MFA2 has gone over 50mpg. Last 2000 odd miles at that average. Seeing close to 60mpg on some journies courtesy in part to Millers Power Plus. Hoping this new stuff will help even more. Doing 350+ miles tomorrow, so will be using a bit more again. Time to find a stockist! :)
I have already phoned around all the local dealers that are on the Millers web site mate with no joy so i have just ordered 5L from fasteronline. I will let you know when it turns up if you want some. :)
[B)] [B)] I need a look under your bonnet sometime mate. :D
Did you try ALS motor factors on Marsh Barton? Just to save me trying there, and you've already tried them and they don't stock it.
:think: The 5 litre size works out quite a lot cheaper than the 500ml bottles doesn't it...roughly half the price.
Edit: Just noticed the fasteronline price includes delivery too :)
Do you just pour the correct amount into your fuel tank when you've filled up?
Or do you need to mix it with your fuel before you put it in?
Might have to give some a try on the new car :)
Whenever I add Millers, I put the additive in first, then fill up with diesel. This should ensure it gets mixed in the tank. I also allow the last little dribble of diesel from the nozzle to run down the top part of the filler neck, to make sure all the Millers is washed down. Maybe I'm being too anal about it... :)
Just pour the corect amount down the filler neck before you fill the tank up. It will mix up nicely when you fill the tank.
Edit: Doh! beaten to it!!
As always, i reset the mile counter when i last filled up and put a double dose of millers diesel sport 4 in with Shell extra.
Anyone else seen that sort of milage from normal daily driving? (Not pootling around and 54mph):p
I'm on 300mileson the trip, bit of raggin it done and country roads on Maxol's finest derv, (70p/ltr and close to work). Am goona try get hold of Millers and see the difference. That is hell of a lot of miles for just over a half a tank!
I know, it's never done that many before and i had an encounter with a CTR on my way to town this morning, and another encounter with Golf GTI MK4 on the way back. Had to have a little play with them ;) Fuel might have stayed closer to half if i'd not bothered, but i bought it for having fun in, so why not?:funk:
Only have the 105 pd tdi toledo, but still good going car, can move for the size of the car. But would like better mpg as do lot of work related driving and have final year to think about......savings!!:O(
going by what have read there are som performance gains if only in the way of smoother throttle and quieter engine.
