stockists can be searched for on the Millers website![]()
thanks, am on 200 and it has just tipped over half!!wasnt rammed full of fuel, just at full mark. not gettin good mpg, 11k on clock though.
Well, I've had a first. First time my long term MFA2 has gone over 50mpg. Last 2000 odd miles at that average. Seeing close to 60mpg on some journies courtesy in part to Millers Power Plus. Hoping this new stuff will help even more. Doing 350+ miles tomorrow, so will be using a bit more again. Time to find a stockist!![]()
I have already phoned around all the local dealers that are on the Millers web site mate with no joy so i have just ordered 5L from fasteronline. I will let you know when it turns up if you want some.![]()
I need a look under your bonnet sometime mate. I have already phoned around all the local dealers that are on the Millers web site mate with no joy so i have just ordered 5L from fasteronline. I will let you know when it turns up if you want some.![]()
The 5 litre size works out quite a lot cheaper than the 500ml bottles doesn't it...roughly half the price.Whenever I add Millers, I put the additive in first, then fill up with diesel. This should ensure it gets mixed in the tank. I also allow the last little dribble of diesel from the nozzle to run down the top part of the filler neck, to make sure all the Millers is washed down. Maybe I'm being too anal about it...Do you just pour the correct amount into your fuel tank when you've filled up?
Or do you need to mix it with your fuel before you put it in?
Might have to give some a try on the new car![]()
I'm on 300mileson the trip, bit of raggin it done and country roads on Maxol's finest derv, (70p/ltr and close to work). Am goona try get hold of Millers and see the difference. That is hell of a lot of miles for just over a half a tank!
Did you notice any performance difference? Cheers
