Dealer awkward about SKC number...
armr1002
Whats the difference in the VAG Com cable and the one used to find the SKC?
Is there a difference or is it the software?
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
i used the software that came with the cable dude...
Vagtacho mainly....as it works with USB
The ones above are all serial ones..
armr1002 - i believe the SKC cable has more electronics in it......its definetly bigger than a standard vag.com cable.....
im sure someone will enlighten us!
matt-doyle
I've tried using vagtacho to try and get the 4 digit code out of my 2002 (51) Leon tdi 110. However i can't access it. It can read the VIN etc. under the VDO setting and the Audi immo setting gives a message in german but neither setting will enable the pin to be read as it can't log in to the immobiliser. Have you got a Leon or an Ibiza?
matt-doyle
I've tried them all but had no luck, only the VDO ones and Audi immo ones work but can't get past reading the info as it won't log in. Just get access denied messages. Is there any way I can check what sort of immobiliser I have? Do you think my car is too new for the 4 digit codes??
Funkyfin2000
Oct 6, 2005
2,477
if its a 2002 it SHOULD be a 4 digit, but they did change them half way thru 2002 i believe....
u have tried to connect to all the ECU's listed?? and only VDO one and audi immo one gives you the READ PIN option???????
My mates Audi A3 and Audi A4 were all under VDO or Audi Box.....my Ibiza 02 plate mk3 was under the VDO old i think...
Just choose those ECU's click to CONNECT TO ECU and then click on READ PIN.
The top of the page will change to logged in AUTHORISED if you have successfully got in to the immo box...
Thats all off the top of my head mind u...
have you got the latest version of vag tacho? 1.7? i think i used 1.6?
matt-doyle
i've tried all versions of the program 1.1, 1.3, 1.4, 1.5, 1.63 and 1.7 and still can't get it to work.
it reports the immobiliser as:
1M0920922D KOMBI+WEGFAHRSP VDO V02
VSSZZZ1MZ******** SEZ7Z0A1373015 - (VIN DISGUISED BY ME!)
after about 100 tries it came up with this (version 1.63)
Connecting VDO New...
OK
KOMBI+WEGFAHRSP VDO V02*\h
Check for VDO tacho...
Tacho is VDO! Try to log in... Please wait!
Software Version: SS5501LM
Password: 21
Check for Seed-Key...
Please Wait....trying to calculate Key
OK
OK
Please try again!
!!! Access DENIED !!!
Trying again just gave me this..
OK
The seed-key message only comes up about once every 50 tries and all times it said access denied.
other failed tries...
VDO New Setting...
OK
VDO Old setting...
Connecting VDO Old...
OK
Immo Box Audi...
Connecting Audi Immo Box...
OK
Bitte Adresse 17 eingeben
Go Ahead!
Reading Unit Info...
Try to Read Immobilizer PIN code...
Please wait...
Error or Access denied!
Any ideas???? :(
Funkyfin2000
Oct 6, 2005
2,477
it looks like its not possible with your car!
very interesting.......
bummer dude...have you found out if you should have a 4 digit skc or a 7 digit skc...coz if its 7 digit skc i don't believe its possible to get it out of the car.....
the only other thing u can do is, maybe get a com cable instead and use the other type of programs......
Are you using the CONNECT ECU button....
what happens when you perss "conntect to any ECU!"
