Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hey Guest💡👉 We have just launched our new Dealer Directory and review service Find out more now
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Basically, you press the '1' button to change the number for the first digit. Every time you press the button the number goes up by 1 digit. Then press '2' button for the 2nd digit and so on. Once you have all 4 numbers correct press 'PTY'.
If you have triggered the safe delay, he bit that most people struggle with is that you must leave the radio on for the delay period to clear. ie switch off ignition, switch the radio back on, lock the car and then wait an hour or so until you can try again. Otherwise it's as people said above.
when fitting the aura back into the slot, is it simply a case of plugging the iso of an aftermarket back into the back of the aura as i have an alpine in there at the moment and im willing to put my aura back in if its simply a case of plug and play as i still have the code
