Wheels: Compomotive MO 16"x 7"
How its lowered: FK Highsport
How low: 60-70mm
Does it rub: Does a little with 15mm spacers on the rear and catches the front splitter at times.
Any arch modications: Yes, arches did need to be knocked back a little bit, along with triming the plastic inner arch.
wheels - 17"x7
Lowered - Evo sport shocks and springs
depth - 60mm front and back
rubs - like a homo in hotpants :)
arch mods - Few bits cut from inner arch
Looks good, but can I throw a little spanner in the works? the pre-facelift ibiza has a lip on the rear arches, its only 1/2 an inch wide but thats what scrapes on mine. just some info for you
Was that aimed at me???
if so its not the outter arch, thats fine. its the entire inner arch at the top, right below my fuel line. and its the whole flat surface of the tyre thats catching :redface:
as a wise man once spoke..."its absoloutly fine!"
Just a point. Don't know whether its been mentioned above, but the only way to truly measure the drop on a car is from arch to centre of the wheel.
You could have a 24" wheel on there but the suspension difference would still be the same even though you could hide small children underneath!!
sorry no it wasn't. Just a bit of info for the mas website. I found that you can run wider tyres on the later facelift cars as the pre-facelit has a small lip on the inside of the rear arch
and yep, its all gravy :D
Just looked at the site looking good but i should have mentioned i dont have any rubbing with mine
Sorry, still haven't got those piccies on 14's for you. Anyway, here is one on 15's. It is lowered 40mm on Bilstein Sprintline suspension package (springs and dampers).
