daz2282
dazza
Oct 13, 2006
76
ayrshire scotland
hi folks got my car remapped by star performance last week, car was excellent when it came back he changed the induction kit, maf meter, spark plugs, and n75f valve, went really well last week but past couple of nights ive been out in it i feel i havn't the same power as last week it kinda comes and goes usually happens in 3rd 4th and 5th round about the 4-5k rev mark feels very flat anybody any ideas what it could be cheers lads
not got a clue mate why he changed both he said he had to im thinking it could be the ecu getting it cheked 2morrow to see if there is any error codes
did he charge you for them?
id be surprised if its the ecu, but there might be a fault code, leak...maf failure...n75 failure...could be anything...vagcom it
I had a similar problem last year, would loose power every so often in 4th or 5th, Turned out a coilpack was slowly on its way out. Was producing a weak spark under load.
oooooook sold you also those extra bits when you probably didnt need them but didnt uprate the crappy standard dv....
Just for your info
The car had a N75 revision E we changed to an F.
The car had a coolant switch fault we replaced it with a green switch.
The car developed a misfire on coilpack no2 replaced with a new unit.
Due to the hoilday weekend our supply from Forge for dv valves was held up.
All old parts shown to the custom.
Jim.
Just for your info
Jim.
Hi and welcome to the forum, Jim. :wave:
