i looked into this ages ago...i think the reason why its one use only is because it works in kind of a "cut and paste" method...so it takes the settings from the KW100 and puts them onto the car...and i believe it does the opposite if you ever wanted to remove the settings (not sure why you'd do that tho lol)
wont this option come on the clifford alarm? self closing windows when car is locked and armed? might wait till then to see and if not il getthis gismo :)
orca what is that bloke in your avatar doing in that bush?
Just had a quick look at round the steering wheel my 06 Ibiza but I'm stumped at where to find the obdII, to be honest I haven't got a clue what I'm actually looking for:doh:
Any tips?
in the drop down draw on the right hand side of the steering wheel open it and force it down even more and it will unclip shine a torch in the hole behind it and you will find an open plug socket this is what you are looking for ;)
It's a cartoon my wife had done. It is me. I was "taken short":whistle: and hadto go in a bush. The trouble was I forgot to stamp the grass down first and got badly stung by nettles!!!;) :blink: :doh:
So what happens if you want to leave the windows open?! (To stop the car getting too hot on a summers day).
where can i find the base code from my car.... so i can try this program?? the only 2 codes i get is workshop and software codes
unit 35 i think it is
the controller for central locking - the base code should list under soft.coding
try the number in the decoder and add/minus what options you want
then recode in advance functions (WRITE DOWN YOUR ORIGINAL)
never tried it on anything but a TT so @ your own risk and you may find options can't be activated anyway
no, it closes the windows and locks a single click, think a double lock press will not arm alarm or lock windows..... i think, but single press def closes them :)
Just ordered a KVW100, pleased a spotted this thread, cheers everyone
Nope!
well recieved my KVW100 today and tried it and it DOESNT work. Al i get are one long beep then about a 25 second silence then loads of contstant beeps (approx 3 per second) and it didnt work. tried it again and still nothing.
This is on a MK4 fr with standard alarm etc
any ideas people!??:cry:
