LCR Owners - Important Regular Check
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Is this true for 1.8T's can't say have ever noticed the sound after switch off myself,but then again not been particularly looking out for it either.
The LC does not have this feature, so that's why you haven't heard it before. It's an LCR only thing.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
really? not doubting you rob as ive never looked for the pump. but i get a wirring sound from the dash centre , almost a gentle bubbling directly behind the turbo. you can clearly hear it if you listen. im certain its a coolant pump indpendent of the engine :confused:
RobM
Sep 27, 2006
4,982
Southampton
As far as I know, yeah. It was a feature of the LCR only. I'm happy to be proven wrong if that's not the case, but I'm sure it is :confused:
phatchoonz1
89
Orpington, Kent
on my last car it wasnt goin on at all waranty job controler changed! pretty sure it was bolted on behind rad under battery ish! bolted to frame rail?
I'm still pretty concerned mine's not pumping. Especially as it sounds like there could be a potential problem with the controller then. Better go and try to find this controller I think...
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
i too get that bubbling sound, i thought it was to do with water pressure and it all settling down when the engine is off
should vag com see that error ?
Deleted member 43482
A word of warning for you guys , if you have replaced your cooling fan control box at any point with one that is not for an LCR , your secondary water pump will not work :) as it runs through this.
This box is located under the battery.
Aug 7, 2009
1,395
Manchester U.K
from my old car, what it looks like, it sits about 3 inches down from there on the back of the rad pack.
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
Just cleaned mine quick Question about Secondary Water pumps when are they activated ??? A certain temp or certain running time
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
naaa mate thats the throttle body lol
Mine rarely comes on that's why id like to know when its suppose to
fuel pump not tb, ;)
secondary water pump isnt as critical as you think , coolant temps rise by 5-6 degrees after the engine has turned off, its purely to stop this, so i wouldnt worry that you're going to do any damage, us non R owners dont need em, (extra bit of weight reduction!:p)
