Boi Ninja
16 valves of sweet shhhhh
Dec 23, 2005
863
Enfield, Shanktown
i just got a cable and had trouble setting it up but once i sorted that i got the following:
VAG-COM Version: Release 409.1-S
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 6K0 906 027 J
Component: MOTRONIC MP 9.0 S038
Coding: 0261204844
Shop #: 1037359163
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
17978 - Shareware Version. To Decode all DTCs
P1570 - 35-10 - Please Register/Activate - Intermittent
Readiness: N/A
Skipping Address 15-Airbags
Address 25: Immobilizer
Controller: 6H0 953 257 B
Component: IMMO VWZ3Z0Xxxxxxxx V71
Coding: 09600
Shop #: WSC 00000
2 Faults Found:
01176 - Key
07-10 - Signal too Low - Intermittent
01176 - Shareware Version. To Decode all DTCs
65-10 - Please Register/Activate - Intermittent
can anyone help me? tried searching on google found some 01176 faults similar but not the 07-10 and 65-10 ...thank u.
i dont have vag.combut from the results it shows that the control module (airbag/seatbelts) is faulty doesnt seem to be anything to do with steam coming from behind the dash!
Where did you get your cable from? i know there is a thread on where to get them, but where did you get yours from and download the software?
Also i had a look before under the gear gator (where i thought the plug in would be) and it wasnt there. Where is it on the Mk2 Beeza?
drop the under steering wheel cubby out, and it's in there on the left hand side
jamin: yeh its under the steering wheel on the left side of the drivers glove box, got my cable from ebay and software was free from ross-tech.
Rashcupra: i skipped the airbags, something saying it might damage it if i scan...i know there is a way past this but im just looking into my heaters right now.
anyway onto my reading? or is asking here useless, should i just try the dealers.
