hardyj
Snake
Jun 6, 2005
114
Southampton
Hi All,
My clutch is now slipping and can only get worse.
Anyone have any good advice on where I can purchase a replacement?
standard clutches try GSF, FPS, ECP, benchmark distribution to name a few, will all do SACHS clutches.
Dependant on the mileage i would suggest changing the DMF, and the CSC aswell, will be a bit more costly, but could save the cluch from needing to be replaced again due to contamination or the clutch failing due to working with old parts.
what engine code is it? ill get you all the part numbers needed now from works website.
wil get you the part numbers for the AUQ engine code then matey
1st is clutch only
SACHS 3000 951 216
Clutch Kit
Engine Code : APP,AUQ,ARY
Diameter [mm]: 240
Number of Teeth: 23
For components see parts list:
3082 311 641 ( Clutch Pressure Plate / 1 pieces )
1878 600 615 ( Clutch Disc / 1 pieces )
4200 080 060 ( Grease (high-performance lubricant) / 1 pieces )
Without releaser
also as Kit plus CSC available
2nd is clutch plus concentric slave cylinder
SACHS 3000 990 060
Clutch Kit
Kit plus CSC Engine Code : APP,AUQ,ARY
Diameter [mm]: 240
Number of Teeth: 23
3182 997 901 ( Central Slave Cylinder, clutch / 1 pieces )
Alternative Repair Kit: 3000 951 216
dual mass flywheel
SACHS 2294 501 039
Not available Flywheel
Dual-mass flywheel Engine Code : APP,AUQ,ARY
Engine Version: For engines with dual-mass flywheel
seems the flywheel could be an LUK one, as its no longer available.
Wow loads of info... cheers Triple D.
So guess I could just go for the 1st choice of the clutch kit then.
I see AVS Car Parts - www.vwspares.co.uk are doing it for £108.16.
Would this be a good price?
Not sure on the price TBH, i can try to find out tomorrow what our customers get the clutches at and find out a price for you if needbe. I work for sachs, so i get them at cost, so would probably be like £40+vat or something silly :lol:
Try GSF, FPS or ECP for a price, they should beable to match or beat them id have thought.
The first clutch was just the Pressure plate and the drive plate. The second one was the whole lot without the dmf, so pressure plate, drive plate and Concentric slave cylinder.
The concentric slave cylinder part number is 3182 997 901 for future reference.
Just checked out the ones you mentioned. IT still looks like vwspares are the cheapest unless you can get a sachs kit for me at similar price?
What price did they quote you? will have a look on monday for you....
what mileage has the car done?
Hi Triple D,
Sorry I have not replied sooner. Been away for a few weeks.
Anyway VWSPARES is as follows:
1.8T AJQ,AMK,APP,ARY,AUQ,BAM (6 speed) Sachs 3000.951.216 £108.16+VAT.
The car has done 79500 miles.
Regards,
Jay
79.5k id advise getting a new DUAL MASS FLYWHEEL & Consentric slave cylinder aswell.
i have mate getting bt to so changed slave, clutch and flywheel, which is suggested esp after them miles
dan seeing how cheap you can get it im wondering about mine now, there are 3 parts in total arent there?
Clutch
Pressure plate
Slave cylinder??
well i have gone for the whole lot mate, the flywheel, slave cylinder, clutch and pressure plate but thats because im going bigger turbo, but from what i've been told its best to replace whole lot esp with your mileage as it'll work out cheaper in long run
well near on 700-800 odd but can get cheaper prob
but if your going standard parts it'll be cheaper
dual mass flywheel, rob payed about £290 iirc,
consentric slave cylinder (bearing) £60 ish
clutch kit £108+vat
think thats about it matey.
pressure plate is in with the clutch kit rob, clutch kit consists of plate and cover, then there is another kit with hydraulic bearing plate and cover aswell.
Hi,
I too am starting to experience clutch slip in my Cupra in 4th 5th and 6th around 3200rpm.
So i guess I may need a new clutch soon.
Car is remapped to near 220bhp (255ft/lb torque i think) 54500 miles.
I just want to get the clutch sorted and am not interested in paying huge money for uprated and fancy clutches.
There seems to be a huge price difference between the SACHS ones mentioned here with vwspares and other ones people are talking about.
I also cant find torque stats on the SACHs ones mentioned here.
Probably going to change it out ourselves.
Can someone please help me out by advising me what is the clutch I should look at getting for what I want and any other advice would be appreciated?
Also I'd like to know what is thought of the SACHs ones mentioned here.
