1st is clutch only
SACHS 3000 951 216
Clutch Kit
Engine Code : APP,AUQ,ARY
Diameter [mm]: 240
Number of Teeth: 23
For components see parts list:
3082 311 641 ( Clutch Pressure Plate / 1 pieces )
1878 600 615 ( Clutch Disc / 1 pieces )
4200 080 060 ( Grease (high-performance lubricant) / 1 pieces )
Without releaser
also as Kit plus CSC available
2nd is clutch plus concentric slave cylinder
SACHS 3000 990 060
Clutch Kit
Kit plus CSC Engine Code : APP,AUQ,ARY
Diameter [mm]: 240
Number of Teeth: 23
3182 997 901 ( Central Slave Cylinder, clutch / 1 pieces )
Alternative Repair Kit: 3000 951 216
dual mass flywheel
SACHS 2294 501 039
Not available Flywheel
Dual-mass flywheel Engine Code : APP,AUQ,ARY
Engine Version: For engines with dual-mass flywheel
seems the flywheel could be an LUK one, as its no longer available.
