car has good moments and bad moments
jason-jm
414
It doesnt seem to be pulling like its 200bhp+
first is fine, second can have a bit of a delay and then it kicks in and all the other gears are the same,
comes to a stand still then kicks...
what could be causing this?
It also doesnt seem to want to exceed 120ish (private track) my saxo was only 130bhp and it used to reach those sort of speeds with ease...
something is isnt right as Everyone elses seems to be awesome at 200bhp:confused:
jason-jm
414
Im going to put the standard DV on later and see if that does anything..
I am right in saying the car shouldnt be delaying and then shooting off then delaying then shooting off in all the gears should it
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
As said, get it on VagCom. I've had sililar hesitation issues in the past. Could be your MAF or coilpack playing up.
jason-jm
414
How much is it for a new MAF..
Im not sure where the nearest Vag garage is (being in mid wales its bound to be 100miles) :(
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Around £70 + your old one at any VAG garage. Try unplugging it and going for a spin. If it drives better with it unplugged then thats more than likely your problem. If it drives the same then its probably something else.
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
No, the ECU will run on a preset MAF reading, it'll be fine, unplug it and give it a good ragging. Although i wouldnt drive it for more than a few days unplugged though.
jason-jm
414
No il only try it for 10-20mins see if its any different..
dont get me wrong when it pulls it pulls hard, but it doesnt feel much quicker than my saxo vts at times :(
jason-jm
414
just got home off work beak, need to be back by 12.30 so Im going to try now...
also I read somewhere about the maf being faulty makes the mpg etc go crazy, mine shows up at 70-100mpg sometimes...
just jumps randomly from like 40-70 - 20 etc etc
sound like maf?
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
that will be the realtime mpg (not really much point having it on that) the average mpg is the one to look at so its prob nothing to do with it
jason-jm
414
Lol why's it showing up like 140mpg on the realtime one?
the average is showing about 23-26
I couldn't take the maff off I didnt realise it needed torx to take it off, il have to give it a go later...
If its the maf thats faulty will the car run well with a smooth constant boost rather than the short blasts?
