question about window repair "picture"
johan karlberg
do i need to put this part back? it is the part that hold the door lock module to the carrier panel..
it is the part with yellow arrows
thanks
johan karlberg
well not being funny if it came off then yes put it back on
hmm.. can you explain a little bit more why i should put it back?
i have not removed my door lock module its left in the door, so if it is just a thing that should hold the door lock module if i remove the door lock module i cant se why i should put i back on..
please explain..¨regards
johan karlberg
what are you meaning with delocking?
i willl not replace the doorlock module.
only replacing the regulator
johan karlberg
Delocking mean removing the key barrel in the exterior door handle to make it look nice...but it doesn't sounds like you're doing that...
aha okey no i just want to fix my broken window regulator..
so the part are only to support door lock module..??
johan karlberg
just supports door lock, not needed but makes it easier to line up the lock to bolt it back into the door.
okey! thats what i wanted to hear.. so for me it would not matter because i have not removed the dool lock..
i get the repair part at wednesday really miss the car now :(
