Wheres the manifold pressure sensor?
Tall-Paul
Previously ph2858 :D
Nov 12, 2006
671
Manchester and Preston
My cars had the VAG-COM treatment today (thanks to Ric 2001) And its got the following error: 17564 P1156 Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
So does anyone know where the sensor is so i can check out the wiring?
tan159753
I thought it was the little sensor in the ecu at the end of the vacuum pipe. If im wrong, whats is the ecu one called?
Tall-Paul
Nov 12, 2006
671
Dunno, I think its somethin to do with this
It was a bit of a bodge job if i'm honest :headhurt: im going to solder it properly and it should work properly. VAG-COM says its not the sensor but a wiring fault.
I cant comment on the ecu sensor, all I know about is the MAF and MAP sensor :shrug:
T. Spark
Yeah mate, as already said, the sensor is plugged into the FMIC. If its short, your car might randomly boost/ or limp until fixed mate.
If it is the sensor itself, its £30 from a stealer!
