Big Problem! Help!
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Hi,
Drivin my car home last night and the car kept juddering like if the brakes were been slammed on and off quickly and it also kept stalling about 5/6 times in 5 miles...... scanned the car with vagcom and these came up..... can any1 help me?
VAG-COM Version: Release 409.1-S
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 6K0 906 032
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 14385
3 Faults Found:
17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :)
P1560 - 35-10 - - - Intermittent
17964 - Shareware Version. To Decode all DTCs
P1556 - 35-10 - Please Register/Activate - Intermittent
16486 - Shareware Version. To Decode all DTCs
P0102 - 35-00 - Please Register/Activate
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 11111
1 Fault Found:
01314 - Engine Control Module
79-00 - Please Check Fault Codes
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
lmfao @ 17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :)
lol, i like how its got a smiley face in to.
I've cleared all the faults and now i've just got a new fault code coming up
T/C light stays on and fault code is Mass Airflow Sensor (G70) Signal too low - looks like a new maf again....hopes its under warrenty as its only been put on in mid november by PSI Tuning,
also the abs fault is still showing..
does anyone know what that rosstech page is where it shows all the fault code and symptoms?
guitarman
you mean this one? :
http://wiki.ross-tech.com/index.php/Main_Page
