Tall-Paul
Previously ph2858 :D
Nov 12, 2006
671
Manchester and Preston
Im having problems with the standard intercooler piping poping off just before the inlet manifold, Can anyone reccommend somewhere in the northwest that can make something a bit stronger than standard? Ive already got forge piping for the intercooler but im not sure if they can make a one off custom bit quickly :confused:
Ive currently got a dubliee clip holding the standard clip on, is this going to be reliable til its fixed properly?
Cheers :D
i had this problem with the same pipe took it back to seat to find the wrong pipe was fitted now its been changed its fine.
Has anyone got details of the top part of the intercooler piping i.e the bit after the intercooler? Diagrams, drawings, bore sizes? Forge need them so they can decide whether or not they can make it.
You would need one of these :D
This is what I want to replace:
I think the first one is the correct one, Who suppliers them? It looks like it replaces the EGR valve (green) However the 2nd one in the link has a bend at the end which doesnt seem to be on the standard pipes :whistle:
I've been quoted £120 for 2 90 degree bends (silicone piping) and metal piping for the middle part. Same as Diss 50 but silicone bends on each side.
Is this expensive?
thanks for the picture. We would need something a little more detaied: pipe dia. , o/all length. We may not be able to produce this. We are limited to the elbows diameters we are supplied. Also involves welding/plishing - might be expensive!
