Remap next week (Custom Code)
Pky
had a bit of a search but cant find much tbh...
im having the car remapped again next week (going with custom code)
realisticly what figures should I see?
the site is saying 190 - 200bhp... these about right?
i know its all a dyno lottery but.... results?
on mikeanics rolling road I pulled 162bhp // 166 lb ft with my current map (Ch1pped UK - 'stage 1') that is boosting to 10psi - not much of a map at all (also done b4 the zorst was on)
specs are (will be)
custom code stage 1, force split-r dv, green filter (smoothed air box), cat back zorst.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Yeah you won't be seeing more than that...
personally I would wait with getting it custom coded, and get a bigger downpipe, TIP and possibly k03(s) first...then you will see a good 235-240 and possibly even higher...
Pky
illd be happy with 190 - 200 tbh... not worth throwing aload of cash at it, end of the day, its an old car.....
or did ya means i cant really expect more then 162 ? cos if so.. thats a bit pants... 7bhp gain... wooo!
warren_cox
Back from the dead
One remap to another will not give significant gains of 20bhp over another.
Mostly its the characteristic of how the power is delivered that may vary. Some come on boost harder than others, but you'd be highly unlikely to see a 20bhp difference from one map to another. Maybe +/-10bhp max, but I'd be sceptical at that.
I'd put your money towards a decent suspension set up to help you realise the benefit of the power you already have
ian_cupra
i'd say around the 190 mark after a custom code map mate, but then you'll be needing brakes and suspension :lol:
Pky
thats fine, i just wanted to know it wasnt wasted money.... the ch1pped UK map is doing nothing... its boosting to 10psi (checked with vag-com and my boost gauge) currently RR'd as said previously at 162bhp which is fook all up on standard.
I know the car is capable as before i had (from the same mapper) another map 'turbo rabbit' which was seeing me spike and 21 - 22 psi and hold at 11 ish... the problem i had with that is the car went in limp mode, they 'fixed' this by putting this other map on... which is toss. lol... soo custom code @ psi turning seems the way fordward....
(that 162 was BHP @ Fly btw... not the wheels...)
ian_cupra
i mean 162 is pants for a car thats supposed to be mapped, either you had a problem or is just isnt mapped, with the mods you said you have int he first post i'd say its on a standard map.
you could have a boost leak, or fault somewhere too though
Pky
cars been checked over by a mechanic on more then 1 occasion, no fault codes etc etc...
im pretty certain its the map...
logged it many of times with vag-com.
when i had it mapped by ch1ppped uk, it went on there rollers and made 206bhp...
one run that i did:
Code:
	Group A:	'005				Group B:	'115				Group C:	'118
		RPM	Load	Speed	 		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 km/h		STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
3	358.04	2440	17.3	61	Part Throttle	358.43	2400	19.5	980	1020	357.64	2480	9	0	1050
	359.23	2360	42.9	58	Part Throttle	359.63	2360	45.1	980	1060	358.84	2360	11	0	1010
	360.44	2440	97	59	Enrich.	360.84	2560	113.5	1750	1470	360.03	2400	11	43.1	1060
	361.63	2800	130.8	66	Part Throttle	362.03	2960	135.3	1770	1680	361.23	2680	11	63.1	1600
	362.94	3240	139.8	77	Part Throttle	363.43	3440	139.8	1750	1730	362.43	3080	11	64.7	1690
	364.25	3680	139.1	88	Part Throttle	364.65	3800	139.8	1770	1730	363.85	3560	12	64.7	1730
	365.53	4120	140.6	98	Part Throttle	365.94	4240	142.1	1770	1730	365.05	3960	14	67.5	1710
	366.94	4520	148.1	109	Part Throttle	367.34	4640	148.1	1750	1740	366.54	4440	17	71	1740
	368.14	4880	148.9	117	Part Throttle	368.54	4960	148.1	1770	1740	367.74	4760	19	73.7	1740
	369.34	5160	146.6	124	Part Throttle	369.73	5240	145.9	1780	1720	368.94	5080	21	76.1	1740
	370.53	5440	142.9	131	Part Throttle	370.93	5520	140.6	1790	1720	370.13	5360	24	78.4	1730
	371.73	5720	138.3	138	Part Throttle	372.13	5800	136.8	1780	1690	371.33	5640	27	80.4	1700
	372.93	5960	133.8	145	Part Throttle	373.33	6040	135.3	1690	1660	372.53	5880	30	78.4	1680
	374.13	6200	131.6	151	Part Throttle	374.53	6280	130.1	1650	1630	373.73	6120	33	85.9	1660
	375.33	6440	125.6	156	Part Throttle	375.73	6480	124.1	1610	1600	374.93	6360	34	81.6	1610
	376.53	6600	122.6	160	Part Throttle	376.93	6680	121.8	1620	1590	376.13	6560	36	80.4	1610
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Aup, You look like a local lad then....what colour's ya cupra? you go up fez anytime? You will be happy with custom code Pky from PSI Tuning-thats were i have my work done.....:D
Pky
ibizacupra:- yes, well, kinda... long sotry, it went to the agent in stoke, it kept going into limp mode (i paid for this) then it went to HQ in bromsgrove when it has been on this map (or lack of since) they just decided to take £250 out of my account being the nice people that they are... I managed to get this back tho through the bank... they however did do a dyno of the car which made 206 bhp are there crappy rollers (a tad off i think). very high losses.... im reasured by these cowboys tho that there equipment is fine ;)... LOL!
M47NER- Yeah im local (from Stone) I do venture into stoke now and then, dont religiously go up fez but pop up now and then... My Cupra is red, had it about a year now... where abouts you from?
Guys at PSI are great, i had my water pump done there, top class work and dont fob you off with crap :D
ian_cupra- believe me, it feels as flat as a pancake, ch1pped UK will tell u differently though...
AVOID AVOID AVOID AVOID! this company! I repeat.... AVOID! lol.
ian_cupra
let us know how you get on with the custom code map when its on then :)
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Awesome....im from Cheadle.....,
Probs seen ya up there then- ive seen 2 red ones up there one of the plates has 777 in it so that could be you...or your the other one...lol, You getting bthe map cheap then there as its 30% off still int it? yeh they are really helpfull at PSI...
Pky
Yeah, still 30% off, so... quite a good price tbh!, my plate ends in BTG :p
I know cheadle reasnably well... know a few peeps from there :D
know any half decent places to get dents out? im thinking chips away in staffrod at the mo.... they've done some work for me before (not dents).
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Were you at that meet at darlesten inn couple month ago?
Summer House in stafford? my mate always go's there for work-bit pricey but excellent work..
Pky
Well, ive been custom coded today, omg what a difference its made! been to manchester and back christ it shows what a pants 'map' chipped UK's was.
currently boosting to around 21-22psi on boost gauge then tailing off to around 11. Think that could possibly higher if i mess with me split R.. sounds awsome tho. lol..
Exaust is popping and banging its arse off now too. lol. sounds mint!
PSI didnt even need to take the ECU out, took some fuses out etc and flashed the ECU - didnt really take long. instant results, will do some logging later but im well happy!
Jason & Crew tbh can take a running jump, please dont mess with ibiza's again till ya know what ya doing? :p
