Interesting ... just driven the car hard and its misfiring around 6000rpm... it REALLY doesnt want to rev past this rpm...
Very odd...
Very odd...
The Map was done by a place in Bromsgrove, Birmingham ... they like their 'chips' and are advertised in the UK
If its not the map what else can it be? - Even Awesome are stumped...
I have contacted P-Torque and they want to take a look at it ... fair trek though but have said if cant find problem then no charge which is top service!
okies
thing i dont get is its gotten worse.. id imagine whatever would have well and truely died by now... or at least flagged a solid fault.
very good offer from PT![]()
Thats what I thought too ... tempted to rip all the boost hoses off and inspect tommorrow night to ensure no leaks and replace the coil packs as well for hell of it so can tick another box.
Not ideal but I just want to get to the bottom of it ... I love the car but Im getting so frustrated with it.
If you sit @80mph in 6th around 3000rpm at constant throttle you can feel the car stuttering in and out even though your not moving the throttle.
No stutter on instrumentation although have always had a speedo needle thats not smooth... is a little jerky wheen increasing / decreasing speed - I think this is normal and the couple I test drove did the same.
I've not replaced the coils yet... as VAGCOM not showing fault codes or misfires on the coil #groups ... hence the reluctance but if people think I should for sake of it then I will... I've asked PT for further guidance although obviously he is busy so I dont want to take the piss.
I will check the battery connections tonight ...
...Will has advised I replace the coilpacks with genuine BOSCH coils.
Actually looks like collecting today...
I'll probably just replace cylinder 1 and 2... take for a drive and if no difference swap cylinder 3 and 4 around...
Sound reasonable?
I thought you were going to wait and take the car to PT rather than replace more bits?
...I could only source two genuine latest BOSCH coilpacks... hence why I only have two... local place cant get anymore in until next week but said they had BERU coilpacks available which are OE to VW so he reckons?
I'm off to collect them in 20 mins ... so if the BERU are any good let me know!
