Forum maintenance upgrade - 02/09/08
Mat
speaking of whooshy dump valves, which would be the best one to get for a Mk3 Cupra
:cartman:
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
I personally don't like the white background. its too bright, I preferred the grey one was easier on the eyes.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
as usual it will be a case of shock horror whats this do where's that why doesn't this work :)
but dooooon't panic - as with every changeover it will all be ironed out and isn't simply a click here it is, it is all a generic process with creases to iron out here n there as with anything
it's all for a greater good namely you lot :):)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
actually the old white one i said the same and stayed grey for ages
i had to force myself onto white but you get used to it i promise
ZBOYD
Looking up at the stars!
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
sorry :redface: this thread just grew too fast didnt realise it had been covered...erm i cant upload pictures in my album..says i need to contact administrator..:(
Probably trying to upload images that are too big. It's limited to 600x600 maximum and under 100kb per image only. Maximum of 5 images total.
Glovepup
Cupra Lova
May 27, 2006
450
Sevenoaks, Kent
i like the new scheme, would prefer a darker background as mentioned. It is very bright, not sure of the window on the first page.
But other than that good work!
andycupra
status subject to change
I think it makes things less 'obvious' when at work though ;) which for me is a good thing :D
probably depends what you usually work on...
Ive had more comments about being on the net today than ever before. But then should i be on here... ;)
Top job guys only thing that I perfur on the old one was the time of post ratter then 1hour ago for example
i to prefer a time.
driveforward
Is at the Nürburgring
Nov 5, 2002
3,245
www.driveforward.com
My initial impressions are mixed if I'm honest.. The bright white background seems 'too much', and the banner/header navigation is extremely bold (already have had a few comments at work).. which isn't helped by the fact that on a 1024x768 res it takes up the majority of the screen, with only 4 threads visible on a new posts search for example.
On the other hand, the forum landing page is much better, and threads are displayed in a much cleaner fashion. I'll echo Pete's comments that it's not too great having the page fully justified to the width of the window though.
westoncraig
reviver of old threads :)
Aug 7, 2005
826
weston-SUPER-mare
i kinda agree.... but everyones sig pics now stand out like a sore thumb!
but i like the white!
maybe some slight shading around the post boxes would be good, it can look a bit too white if you get me :)
otherwise impressed though
ZBOYD
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
As i already said, this is a coding bug were looking into, but it's not as simple to fix as pressing a few buttons sadly.
ZBOYD
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
Frankly the whole using it at work aspect, I really don't get. If you can't view it at work, in all honesty don't view it at work. You can't stifle a design by making it comply with your work ethic.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i actually like the 100% width as it shows just the right amount when i shrink the window down at work
if you need to hide it try that - works a treat
personally as long as i'm not stupid it's not a problem anyway well i am the boss so i guess i lead by example - or supposed to :eek:
