Here is a picture:
The car needs to be lowered in order to look good.
I like. Just need centre caps to look better I think!
i have a set of VW santa monicas sitting in my garden...
the specs are
17" 7J Et38 PCD 5x112 ......Will these fit? i know im going to need 100>112 adaptors but even with them will they stick out too far (then i guess stretched tyres will help) or will they rub?
Will work on the rears with 20mm adaptors as my old BBS LM's were ET38 and I had a 20mm spacer which made ET18.
Fronts i'm not so sure - you can get 15mm adaptors and that'll be ET23...
Just buy my Mercedes rims dude ;)
Noticed a thread on the go so thought I would post here. Spotted a set of these for sale 17x7.5(front) and 17x7.75(rear) with an offset of ET33 all round. They're also 5x100. I think they will fit but wanted to double check. Any idea?
Does anyone know if either the Mk1 Leon FR rims (not the cupra style) or the new style Audi S8 rims are Brembo friendly? I'm planning an upgrade but am already £300 down due to buying something that doesn't clear!
Does anyone know if 16x9j wheel will fit my 03 Ibiza. Have found some borbet a's that i'm hoping will fit. I've seen them on a fabia in same size. Just wondering if i will have steering issues etc. Will it need archwork?
So can some one please summerise what max thickness alloys you can use on the front and rear,
also i'm running stock brakes and not looking to upgrade them.
Am I thinking a merc alloy of
8.5JX18H2
ET47
5X112
will fit using 20-25mm adapters?
What the biggest or smallest offset you can get away with?
8.5JX18H2
you will struggle on the front...with 8.5 18's rashcupra fitted them with maj arch modding
ET47
too high - even with 20mm adaptors it brings the et effectively down to ET27 which maybe to low on the front...
5X112
Wrong PCD 5x100 needed...112 - 100 adaptors will make it fit but you have loads of other issues that need adressing not just the PCD...i.e the thickness and ET of the wheel...:(
i would like to know does anyone have the leon cupra fr 17" alloys on the ibiza, the ones which identical to the leon cupra r rims 18" as i mite think to get some???
if anyone has piccys if pos please??
many thanks
Hi, new here, looking to get an Ibiza Sport but already looking for mods ;)
Just wondering whether a set 16" 6.5j offset 43... 5x100 will fit?
Might just get a set of alloys now if they do fit :)
16" 2001 leon cupra rims fit over the 312mm brakes ok? not got the brakes yet but they should be a future investment
will these fit?
Hi guys,
I have bought some TSR Sugo's for my 1.4TDI mk 4 ibiza reference but my current tyre size is 195/55/15r but the news ones av bought are 195/65/15r will these fit straight on? I hope they do, but I wont get the fitting kit till the end of this week, i.e sprigot rings, bolts, the alloys have this funny bolt structure on them too, like the bolt holes are not centred , you have to do it yourself by twirling the bolt hole so it fits the hub, will this pose a problem?
the fella said they will fit cuz the books says they will but i dont feel 100% convinved.
oh will this void my seat warrenty too?
cheers
