N249 bypass
footlong
228
South yorkshire
I've done it an noticed a masdsive difference. Namely my peak boost pressure pressure is now 5psi. Limp mode.
Thanks, but no thanks.
Dan:confused:
Pidge
I
Oct 11, 2008
76
Aberdeen
Youve done something wrong then mate :thumbd:
Check your black and white check valve is in the right way round first!
Might help if you post a couple of pictures of how youve done it so we can maybe identify the problem aswell :shrug:
Mat
Dan:confused:
What exactly do you mean by that?
Maybe something is wrong somewhere. You checked the massive N249 thread????
footlong
228
South yorkshire
No, done everything right. i think it is caused by boost spikes. runs ok, dv sounds better, off boost driving is smoother, but occaisionally i get a limp mode after a "good push".
I'm thinkin a map will get this sorted.
Nov 2, 2004
9,334
South Wales
Overboost on a standar map (cupra r) thats all, if you were remapped you probably wouldnt get it. I've never hit limp mode for overboost since i've had the car.
Pidge
I
Oct 11, 2008
76
Aberdeen
Thinking about it Willz might have been hitting limp mode aswell, Cupra R making ~5-7psi and turbo having to work extremely hard (very hot after only 2 mins!).
And he did have a fault code for overboost aswell!
Although it did have a really nasty misfire between 4-5k rpm :blink:
