I just want it switched off, and if it comes back on then I'll get a full diagnostic done.
But the dealers want £60 and will undoubtedly find plenty of things that need fixed (but don't really) and which may stop the light coming back on but which may not.
Which seems steep for 30 seconds work with a laptop.
So I just want a quick and easy way to turn it off. If it comes back on I'll need to see them I suppose.
What fault codes were logged? Do you know that you can buy a code reader/clearer for about that money from Gendan and it covers all pre and post CAN VAG cars? Also did you know that the light will go out by itself after the car has been started 6 or 7 times after the last time the fault existed - but the code will still be held in the relevant controller's memory?
not always true about it going off, when mine ahad a egr fault the little bugger come on and stayed on despite being driven probally 20odd time before it got to the dealers
Yes, but I would guess that your fault had become a "hard" fault - not a transient fault. I think when the EGR valve gives trouble it usually needs removing and cleaning before it is cured and the fault has gone.
