( have the left hand tube!)- should it be another longish piece of tube, or does it actually plug into a block somewhere? Its an absolute pain!Hi All - a question to those who have managed to fix this by themselves...
My rear washer is off under the airbox too - ive had everything apart but still cant find where to connect it back into( have the left hand tube!)- should it be another longish piece of tube, or does it actually plug into a block somewhere? Its an absolute pain!
If you look just under where the ECU was (if you have taken it out), the pipe comes out of the bulkhead to the left of it (behind the metal thing with pipes coming out of it! I will find a picture for you... Right, the tube is located behind the metal thing that is to the left of the red circle!
Cheers Mike - I'd give you rep if I could!
Have you fixed it? I ran the pipe in front of all of that crap so that I could connect it easily and tape it up too! Have you fixed it? I ran the pipe in front of all of that crap so that I could connect it easily and tape it up too!
Ive been out and had a go but the end that you suggest is the end that I have! (the water doesnt come from that pipe, it goes through it to to the back of the car, when its connected) Still cant get my mits on the other end! Do you think I'll be able to access it by taking the wheel arch liner out and get it from that end?Maybe I should have tried it before I replied!!
You can see where the suds are on my photo just below the red circle. I ran the rear jet for ages to see where the stuff was coming out...That other end ran under the airbox and headed into that red circle area on my pic. It should just be sat there... it won't have gone far if the pipe has popped apart at that join!You can see where the suds are on my photo just below the red circle. I ran the rear jet for ages to see where the stuff was coming out...
The water is actually coming from behind that box thing under the ecu! Hopefully its just that that side of the join has somehow ended up behind there and I can find it, pull it out and connect it round the front incase it happens again!
