pedal box snapped
the passenger
[/IMG]
hi all this is what has snapped off, is the hole piece removable so i can get a new bit welded on or is it long gone.
i have searched but only find threads on the pedal not the bracket that holds the cable any advise would be help as i will be doing all the work my self :banghead2
the passenger
bump
i really need help with this do i have to take the lot out it does bolt on but not sure how many places
the passenger
cheers i was having gander this morn and looks like the steering column has to come out to remove the bit i need to get welded is this so or can i shimmy it around and do all the other pedals have come off as this would make me a unhappy bunny it looks like a lot of work to take it all out plus the air bag etc:cry::cry::cry:why o why did i do electrics instead of mechanics:confused:
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Yes you have to take it all out, column pedal the lot to do the best job, however if you or someone you know is very handy with a welder and not bother about tight spaces you can do it in place. Just remember there is a lot of sound proofing and insulation in that area as well as the main electrics for the car, so small fires from welding aren't advised.
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
my clutch is making a noise when i release it now, i noticed a squeek a while ago and its got worse, just clicked on what it might be... still not sure if its the pedal box or the clutch that has gone or should i say going...
makes a squeeking noise only when you release the clutch really, any ideas what it is guys?
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
Your best bet would be to take the drivers side glovebox off and have a look at the pedal box assembly. You WILL notice if it is broken in anyway.
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
yeah just had a look at it 2day and when i pressed in the clutch with my foot a peice of metal fell down :(
i tried to do it when i was looking at the box but cuddnt push the damn clutch in at that angle! my head was in the way aswell lol
anyone know how much you can get a pedal box for???
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
just rememberd this happened to my dads cavalier last year, he took it to our local garage and they just welded it back together... think this would be okay? or with the ibiza clutches being so heavy just getting another box incase it snapes the welds again?
CraigW
Craig.
Apr 12, 2007
4,607
I have a bit of metal missing from mine but the pedal box is fine. I have an m8/m10/m12 high tensile (strength) bolt going through mine and it was welded back up aswell. Had it like that for nearly 2 years and its still fine.
Maybe worth changing ur clutch and/or cable.
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
dropping the car off not so they can have a look, ill ask how much a new clutch would be aswell, hopefully i can just get my box welded back together and strenghened, thanks for the help guys, ill let you know the score after :)
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
got my car back today, got my pedal box welded back up, havnt had chance to check out how it looks yet since i kinda ditched college for 10 mins while i picked it up :p
got a new clutch cable fitted too....came to £65 all together, the guy at the garage said the clutch cable was £40 on its own, is that about right anyone know?
oh yeah and it feels like im driving a new car now, not heavy at all!:D
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
sounds like you got a good deal there!
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
thats sweet then, cheers for the replys guys :)
hopefully the weld job is good, and there isnt anything melted under there, didnt ask if he took the box out to weld or done it as is...
