*hooks up the air powered grinder to the compressor*
hey up - what ya got that out for ?
wire cutters
crimpers
couple of spanners
small ratchet with a 10mm socket
and a can of coke of course as the sun was out![]()
im guessing with this its the more earthes the better then
I think its the same principle as TB3
sorry for being daft but whats that?
im on here to learn btw![]()
Battery negative to body.
Do this in 0 gauge too (I think this will solve your problem alone)
Alternator positive to battery positive
One step down from 0 gauge would still be fine imo.
Engine block negative to battery negative
Final step, leave main earth strap, just add this extra cable in... The idea is to create a bottleneck free circuit from the alternator to battery and back. So from Alternator mounting bracket to battery, again biggest gauge, but a drop to the next size down would still be improvement.
TB3 = The Big Three
A very popular and good way to improve the charging system in ther car
battery > ground
engine > ground
alternator > battery postive
ahhhh okay thanks for that i htink im going to have ago this weekend then if i get chance
