Grounding Kit
Mat
Has anyone done this to their Ibiza? Those who have, is it worth it?
I remember seeing it in General Chat ages ago, and I've noticed the subject popped up again today. Was thinking of maybe doin it as it's only a cheap "mod" and adds more colour to the bay :D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
:search: 'grounding kit'
but yes even if only for the phsycological untestable reasons and the fact you can make one for £5 you can't lose :):)
Mat
sorry, "earthing kit", is that better :p
wondered if there was any proof. I noticed the comment, "increase MPG/Fuel efficiency". Is that true? Can't see it TBH. And if there is an improvement, it must be minimal TBH
Mat
how did you do if for £5? where do you get the wire and connectors from? Think I have some small connectors at home.
Not exactly rocket science soldering and crimping some spade connectors to end of some wire ;)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i run a motor factors :p
handful of yellow ring terminals from work for £2
maplins for some decent awg cable for £3
job done
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
Just a quickie...
He starts off at the strut tower and then that cable runs to the second location on top of the rocker cover where the coilpack is and then from there to the wing on the other side?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
all about joining clean locations / bolts as close to electrical items to as clean an earth as possible
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
*hooks up the air powered grinder to the compressor*
hey up - what ya got that out for ?
wire cutters
crimpers
couple of spanners
small ratchet with a 10mm socket
and a can of coke of course as the sun was out [B)]
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
wire cutters
crimpers
couple of spanners
Was a bit extreme to mention the grinder to clean the surfaces, should have said emery cloth :cartman:
A can of coke, I wish. I will be need those chemical hand warmers at the rate of this weather lol
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
sorry for being daft but whats that?
im on here to learn btw :D
TB3 = The Big Three
A very popular and good way to improve the charging system in ther car
Taken from talk audio
Battery negative to body.
Do this in 0 gauge too (I think this will solve your problem alone)
Alternator positive to battery positive
One step down from 0 gauge would still be fine imo.
Engine block negative to battery negative
Final step, leave main earth strap, just add this extra cable in... The idea is to create a bottleneck free circuit from the alternator to battery and back. So from Alternator mounting bracket to battery, again biggest gauge, but a drop to the next size down would still be improvement.
Dan1.6
1.6 Power FTW!!!!!!!!
Sep 26, 2008
981
Chesterfield
TB3 = The Big Three
battery > ground
engine > ground
alternator > battery postive
ahhhh okay thanks for that i htink im going to have ago this weekend then if i get chance
Dan1.6
Sep 26, 2008
981
Chesterfield
ahh thanks mate that help a hell off a lot more im goning to order some wire and have a crack at it lol
