with the first surround it can sit flush but you have to cut the cables to remove the clutter and it will go all the way back and sit flush and looks pretty oem also with the red lights
I also got 900BT fitted, and it also doesn't fit quite right:
I'm not allowed to post images yet due to post count, but see:
tyyni.com/imgs/dash1.jpg
tyyni.com/imgs/dash2.jpg
(note: you need to add www)
Like you see on the dash2.jpg, it pushes out quite a lot. But the main problem is that the frame doesn't fit well at all, and the colour is wrong. My ICE-dealer who did the fittng already ordered a new frame, but it was still the same wrong color. Don't know where they did order it, nor is it a Seat part or some 3rd party part.
Anybody has any idea what is wrong? Is that color for some old leon edition? Mine is '09 Ecomotive. I also though about getting aluminium dash trim kit to solve this problem (and it looks quite nice), but does the Seat have then available for aftermarket double-din stereo + climatronic? If so, does anyone know the part numbers for left-hand-drive car?
Thanks for helping me in advance!
Ps, sorry for the dust in pictures, it was bright sunny day and these pictures weren't ment to promote the coolness of my dash installations but the present the problem![]()
If you give me your vin/chassis number VSSZZZ1PZ . . . . . I can look up proper lhd part number for you![]()
Nice!
Mine is VSSZZZ1PZ9R044559
Thanks! This information is going to be really helpful!
How about the other question, is there aluminium dash kit also available for that setup?
Not with 2-din as far as I know.
All accessories for sale are chosen by the importer for your country so I can only check UK
One more question, how many of those 3B0867190 clips are actually needed?
Or is that part number for the neccessary set?
I ordered 6 with my fascia, on the advice of the parts guy - but I never got told how many they actually used.
Folks with F900bt,
Im looking at the cheaper F700bt and was hoping for some feedback on the unit (which look amazing BTW) - i think they are same apart from DVD capability;
I do not have factory Bluetooth, does the CAN Bus leads allow for all steering wheel controls to work (i.e. volume, skip track, select input type etc)?
Is there an external mic for the Bluetooth? Where have you located?
How does the sound quality compare with standard HUnit? (im running stock speakers which i think are aw right)
Does the SD card allow for high capacity types to be used (8-32gig)?
Does the Ipod cable allow for full Ipod control on the unit?
Does the USB input allow for a USB powered HDrive to be used? I recently got a 500gig effort for less than 80 notes, would be sweet to stick this in the glove box and ditch all my cd's for good...
Could you provide a quick overview of the sat nav functionality... go on go on...
Finally, im a tube, would you recommend prof instal or suck it and see myself? Any place near Glasgow area???
Im still half alseep so sorry for many many typos and list of questions, the unit does look so good however!
thanks for yer help...
D
