oh good old mall grips (sp?)
one of my mates borrowed (aka stole them lol) from my car, will have to get some more!
i had my throttle body replaced because a little switch had developed a fault causing the engine to die every time i stopped took it to a dealer they said lamda sensor took it to my local back street garage throttle body guess who wont be going to the stealers for a very long time
just got round to takin the throttlbody of today and i took the switch and all the electrics of it and i put it in some very soapy water its come really clean but iv just been thinkin was it a good idear putting it in soapy water or not :confused::confused:
i am guna oil some of the bits back up eg the spring and the door thats inside the thorttlebody
How did you take the electronics off the tb? And is this off an 8v?
hi its the 16v i justpulled the switch of and the other bit on the side
erm it maybe a good idea to make sure there is no soap at all on it then make sure its 100% dry before reassembly as anypart that has soap or excess water on it could throw out the whole mix and cause a whole world of trouble for you make sure everything fits together as it did when you disassembled it and make sure all the plugs are ok not bent or damaged if this is all done then you should be ok with no problems but for future reference use a carb cleaner and a cloth to make sure its all clean and try to steer clear of soap and water
It should be fine mate. I would have thought you would have put it back on covered in soap sudds. lol
glad to see this thread come back actually as brought a can of card cleaner at the weekend and gave the misses 8v a good few squirts and the got her to rev it a bit and did a few more squirts.
The results were fantastic and it feels like pick up has improved ten fold !
hmmm i never tried card cleaner mate, might have to :p ;)
but your right mate, makes a massive difference, i want to take mine off when i have time and properly clean it, maybe even sand it down to make it smooth (if theres nasty grime), that's for when i have time (easter weekend maybe?) but i need to get a new TB gasket
haha, sorry...been at a fast and furious preview screening and had a few beers....typing isnt so good.
Yeah, am yet to play with the can of carb cleaner on my valver.
stripping is all ok just make sure you put the throttle switch back 'exactly' as you found it
yea i will seems pretty easy to do thow im guna oil it up before i put it back on where should i oil and what oil should i use would WD40 be ok or not
wd40 in the nooks and crannies and give it a shake off and you'll be fine, personally i prefer duck oil :)
i have just a bit of oil down the acclatration cable just to eaise it a bit stop it stick in the future
