so to clarify the tt bushes will fit the lc? mines a facelift 52plate?
lehmanns terms on cost and part numbers i definatly need for these please guys
help much appreciated
also i want to replace front and rear bushes, thinking of buying new wishbones to do at my leisure then.....
i know its the dreaded bay but for example.....
http://cgi.ebay.co.uk/VW-GOLF-MK4-R...14&_trkparms=72:1683|66:2|65:12|39:1|240:1318
or this, same part number as listed in the first page
http://www.vwspares.co.uk/product_info.php?products_id=801
do i need just these bushes or the fronts aswell?
It's 8N0 407 181 B, you need two of these :)
Neil.
I posted the part numbers on the second page :)
I would buy genuine audi bushings as I would be weary of the quality of spurious ones.
rite, ive also posted genuine parts aswell??
so to answer my question, do all bushes need replacing in the wishbone or only really worth replacing the rears?
So on the LCR...willie & nautilas have said replacing the rear bush with the Audi TT roadster bush....and if need be or whilst your at it you can replace the front bush (if worn) with original LCR or uprated bushes.
and the LC...Audi TT bushes can be fitted on the front rear
While your in there ding the rear bush its not worth refitting with old bush in there.
There only £15 each.
If you don't you'll regret it and wish you had done this
thats what im after, pmd dave at sere see what he can do...
just be easier to get a new wishbone, and insert new bushes.
quite looking forward to this one.
I don't get this....according to vagcat its the front bushes that are different, not the rears.
LCR FRONT LOWER ARM
Rear Bush 8N0407181B (Audi part number 8N)
Front Bush 1ML407182 (Seat part number 1M)
TT FRONT LOWER ARM
Front Bush 8N0407182A (Audi part number 8N)
As above, the front on the LCR and TT are as stiff as yu get. The rear wish bone and subframe bushes on the TT roadster are the stiffest in the VAG range
This is only because you've searched for Leon Cupra R rear bushing, which is the same as the TT, has the same code and appears in the dealer database in the same place :p The Leon Cupra/Topsport/FR has a different bushing, which is drilled, soft enough to be twisted by hand, and replaceable by the LCR/TT item... so that once you have a LCR, it's no use to seek a harder bushing at all
~Nautilus
