has anyone got a picture of where to plug the oil temp sender in ? All the threads that I can find have pictures that are no longer hosted. I think I know where it needs to go but would like to be sure. Undoing the hex bolt should be easy enough but getting anything in there looks less fun.
I have an LC not an LCR but I imagine it is all in the same place.
Thanks Lee, the link you posted in isnt working.
But here is the proper one should anyone else want to see http://i167.photobucket.com/albums/...mp Sender Location - LCR/DSC001851280x768.jpg
Do we need to use PTFE tape on the sender? I've read somewhere that doing this will prevent the sender from earthing properly but my sender has an earth cable. Also, when the blanking plug above the oil filter is removed does the sender just screw in without the need for any adapters?
i finished mine today an when i turn the lights dim an bright the oil temo goes up an down? anyone had this problem. i have took feed off the dimmer switch as only ignition live i knew off,
