Error Codes
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
im sure todd would point out now that unfortunatly you cannot purchase standard actuators lol you would have to find one from another turbo
i dont personally know if you should be able to move it by hand or not, but i know it certainly shouldnt be easy to move so i guess its how much tension is left in the spring
its annoying, usually these signs point straight to the n75, swap it an bang cars back.
893
Walthamstow
bloody hell!!! soo the forge one, does it come in the correct size or is it a case of it comes in one size and u have to drill the hold to allow for the actuator to fit?
Oct 17, 2006
893
Walthamstow
yes mate it was - the obvious thing- MAF/Split hose -
first it was a split hose which i replaced and worked for about two days then went back in to limp mode - then disconnected the maf and worked fine
reason why i didnt suspect the maf at first as it was only a couple of months old -
it was reading to high hence chucked up the positive deviation
