well for so many hundred pounds i can get a replacement carbon bed!...please make donations payable to sammy crezz
weld it,fill it and rubber coat it, mind you they do look so sweet when cleaned up
btw look up a bit - ollie mentioned a 2.0 8v ^^^
yeah its all been patched up but its so wavey theres not alot of point and to be honest imay lay down some checker plate on the deck in there bt keep the sides showing...im thinking about seeing if a faricator could make up a huge new ribbed section as ive got the diagram of what needs to be done
as for the engine im damn tempted, may have to ask the old man to borrow some money.. since being assulted ive not been alowed back to work for 2 weeks so money is non existint.
well got the dash out, a little bit of swearing as i couldnt manipulate the movement and unplug things on my own but its out! woop
but i actually forgot to take pictures of inside! do'h
or how about i get the caddy finished in paint,, get it on the road then buy something mental to put in there!...g40 if i could source one...g60 if not......or turbo a vr6?? or being a tad more back to earth....a gtd golf engine tuned to 140 ish bhp and stil return roughly 40mpg
Got a couple of sneaky shots of the one that's rarely parked down the road, doesn't look half as good as I remembered it to be!
hang on i've had a plan, if the beds rusty get rid and mount a V8 in there feeding the rear wheels, would be a hell of a job but would certainly be unique and bloody crazy all at once
too late :) - with those rear springs and a few axles lying about i have already figured that one out
well got the welding done tonight s should be able to crack on now as there aint alot holding me up...just got alot of grinding and a bit of skimming to see it look ok!
