Boost Gauge Fitted, PSI seems low
tripdiesel
Leon Cupra R 225
Mar 21, 2009
162
Isle of Wight
What should i be seeing on the boost gauge, it seems to spkie at 7PSI and holds a constant 5PSI, this is on a BAM LCR the range is -22vac to 7 psi.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Standard LCR should peak around 12psi and hold around 9-10psi. check for boost gauge hose for splits :)
DannyC87
Mar 4, 2008
3,459
main place i'd check it where it comes through the bulkhead; just incase it has snagged something. check connection both ends too. Does the car appear to be driving normally, or is there an obvious lack of power? might be worth getting it on vagcom before you go to the effort of checking for split hoses to see if there is another fault logged causing the low boost?
tripdiesel
Leon Cupra R 225
Mar 21, 2009
162
Isle of Wight
Is it got anything to do with me taking the feed from the top of the DV, should it be somewhere else? A friend just mentioned to get closer to the manifold.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Vacuum is vacuum, but, the dump valve is controlled by the N249 as well, just take it from the FPR, which gets it's from the inlet manifold.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
better to take it off the fpr than dv apparently... but mine comes off the dv and it reads as it should so i doubt its your issue.
you really need vagcom to tell you the real boost levels... only way to be 100% sure.
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
I know this may sound silly, but when I fitted my Boost gauge, I'd unplugged the N75 elec connector, and forgot to plug it back in after finishing the install.
I got a very similar issue, where it would hold a very constant 4-5 psi ALL the time.
Yes I know I was stupid, especially as I was asking all sorts of questions on here to try & work out why it wasn't boosting.
Anyway, may be worth checking there before you start pulling everything apart ;)
