Quick boost question ?
jamiebennett81
On standard engine internals is 21 psi boost with a good map safe ?
yep should be fine on the standard turbo, so long as its not a massively aggressive spike (bendy rods)
why, what map you got in mind?
jamesgtturbo
55
derbyshire
The car is already running 21 psi boost , seems quite smooth boost delivery , apparently k04 set up still not 100 % sure on that though ! got a power graph for 253 bhp , mapped by jabbasport
thanks james
jamiebennett81
thanks james
yours is a k04 stg1?
jamiebennett81
Sorry dont mean to sound thick ! not 100 % sure what it is i was told when i bought it , it was a k04 ! do you mean the smaller k04 ? not the one off of the 225 bhp engine
thanks again james
210 and 225 are both the same turbos I believe, but just mapped differently
you drive an LCR yes? and which version, 210 or 225?
either way, 21psi is fine
jamiebennett81
no sorry mate an ibza cupra mk3 thats been fitted with a k04 turbo !
ah right, got ya mate
as said, 21psi is fine, and if it has been mapped by Jabba then it will be progressive and not aggressive which will be fine on the rods
