ok based on the comments above the dv should be fitted with horn pointing up? surely this means the air is being forced back into the tip which isnt supposed to happen is it?. I thought it should be set up the same as the standard dv which is recirculating into the charge pipe
Mark
Also try and have a non-t'eed vacuum source directly from manifold to dump valve if possible - teeing into the vac pipe weakens the vacuum and affects how the valve operates (might not open far enough to properly vent).[/QUOTE
is it possible that if the teed pipe is not pulling the piston up that is the cause of rough idle
and fluttering?
rob are you running a boost gauge ? if so where are you taking your vacum from.
Just fitted mine dont it sound nicei need a boost gauge tho to check the boost anybody done this ?
How do you compare it soundwise against the a fully recirc/007?
Are you running a standard map?
I might have to invest and see what one of these comes out like with more boost...
yep all standard other than what's in the sig mate sounds really nice when changing gear,
I was like you thinking should i but now i got it and i wouldn't swap it for the 007![]()
